turbo suggestion
monster111
hi sifu-sifu,
for a 1054cc engine, targeting around 160-180whp, 7500rpm max, prefer boost to come before 3krpm.
what is the best turbine can get? rojak or original also can..
assuming money is not a major problem. please give your suggesstion.
thanks
hi sifu-sifu,
thanks
a nice piece of gt20 should bring u there, bt im nt sure if there is a ballbearing for it
GT20
GT2530R
GT2560R
K04
KP35
TD04H
TD04HL
HX20/25
RHF4
RHF5
..........hmmm....
rojak vr14 rh4 subaru legacy turbo will do fine....rear housing changed...center catridge ball bearing....... 3k rpm boost will start to come in....full [email protected] bar by 4k plus....till end...
Thanks for the reply guys..
I though about garrett gt20 too..based on online calculator my setup need around 2.5-2.6PR (1.5 bar).
how much would the gt20 cost? Sdf do you mind quote me a price for gt20?
If i go the cheaper way..can rhf4 exhaust housing be fitted to rhf5? Or can i fit rhf5 compressor side to the rhf4? Rhf4 seem at be at their limit on 180hp..at 1.5bar. While rhf5 (vf34??) from legacy single turbo will seem to lag a lot on 1.0 engine.
How about using complete td04l gsr twin fin or td05 13g vr4 without rojak? Can it meet my goal and will it be too laggy?
Sorry for the long question..i dont want to go wrong with the turbine..
wow 1L use so big turbo...
use TDO4 enuff la...
or gt25 with ca18 front kipas and .47 t2 flange behind. sure ok one..:idea:
can i use ar48 from ca18det? will it be very lag?
how about if use whole td04l gsr will it be very lag?
turbo lag is determine by what? the compressor housing or exhaust housing? why my 1.0 engine can put 1.8 (td04l gsr without rojak) turbine?
sifu-sifu pls explain to me..
isnt lag u need to worry 1st..boost threshold u need to worry 1st then u will consider the lag factor...turbine housing ratio is most important thing of all.. it will determine the characteristic of ur engine boosting...rule of thumb...bigger a/r turbine= more power...bigger turbine=higer boost threshold=higher spool up time = worst enginering = worst performance..
ur question 1.0 can put 1.8 turbine?..my ans is hayabusa with gt40 turbine..how come hayabusa used gt40?
find ur redline limit..horsepower target..engine displacement..engine setup character.. these will help u find the rite turbo for u...:nurse:
thanks bro..
by turbine housing u mean is the exhaust housing rite?
bigger a/r compressor housing = more flow, less boost rite? then bigger compressor fin + bigger housing = more flow more boost = more lag is this correct? by fitting a small exhaust side to a big compressor side can solve lag problem but what is the disadvantage?
i understand what u trying to say 1.3 hayabusa put gt40 becos they have very high rpm so lag isnt a problem.
my redline limit is 7.5krpm so mean i put td04l gsr my off boost performance would be like shit rite? can this be avoided by using smaller exhaust housing? what exhaust housing can put at td04l gsr? i want little lag and good top end power (is this even possible?)
thanks bro..
ur statement regarding bigger a/r compressr housing = more flow.. idont said it wrong but not too rite la..for me bigger the fin= more air flow..u should not worry about the compressor housing a/r..the effect can be neglected ..then u said less boost?? i donno y u said this...may be i dont understand ur statement
then "bigger compressor fin + bigger housing = more flow more boost = more lag is this correct"
i donno where is this come from...no comment.."fitting a small exhaust side to a big compressor side can solve lag problem"...yup..that is a simplest thing to correct spool up time...small turbine mean less power..but responsive at low rpm...top end.....Dont ever think about it..:nurse:..
"i put td04l gsr my off boost performance would be like shit rite" i donno u built the engine..but if u used complet 1.8 turbocharger to u 1.0L engine..i think ur engine will suffer to feed the turbo..find smaller turbine a/r rojak it tdo4l
" i want little lag and good top end power (is this even possible?)"---man made turbo not turbo made man...:biggrin:
gud luck with ur project..there is alot of successfull rojak/hybrid turbo been done to feed 1L engine...Happy BOOSTINGGI:slug:
i got best turbo for u!
confirm chun! toyota hilux latest model turbo..comon rail turbo...
very small and nice....
0 lag...
RM800 mint condition milage 13,000kms..owner changed to gt25 in his hilux...kekekekek
0 lag...
after owner change to GT25, how the performance? use what to tune the fuel ar?? power ke? hehehe
peformance better a lot...
from 88hp to 139hp but change turbo,add intercooler add oil cooler,boost controler,ecu..etc..
yah...
lotsa power increase and heaps more torque...
buy brand new GT25 la...
sure CHUN la!!!
i think still on promo while stocks last la..
