Kaitospeed : Brembo Sport Disc Rotors Evo5/6/7/8
kangyoon20
Over 10,000 RPM!
Malaysia
Brembo Sport Drilled Disc Rotors
Lancer Evo 5GSR/6/7/8
Features:
  • Forged from high-carbon cast iron
  • Cross-drilled design evacuates heat and refreshes brake pad surfaces for better bite
  • Drilled surface also wicks water away from the rotor surface, noticeably improving brake response in wet weather conditions
  • Directionally vented for maximum grip and centrifugal evacuation of heat gasses
  • Work with the stock calipers
  • European TUV certification for quality
  • Reduces braking sound through the higher damping coefficient of carbon steel discs
Brand New 1 Pair in Box
Front RM1800(last set)
Diameter : 320mm
Thickness : 32mm
5Holes
Rear RM1700(last set)
Diameter : 300mm
Thickness : 22mm
5Holes
Front+Rear = RM3400
COD JB/Malacca
Skynet Courier Service Available
PM or Contact 016-7442406
Kaitospeed Performance Autoparts
Bro, u have for rear? Oversized from original is available for evo ... 5 holes
Bro,
Selling any Brembo brake pads or not for EVO 7 ? How much would it be if for front and rear barke pads.
Have a nice day!:rofl:
Does it fit into Lancer GT?
Bro,pls quote for my airtrek disc, front only and send to terengganu. Lst time I'm using brembo max for my gsr, why it cepat karat2 ??
Pllp
Lancer Evo 5GSR/6/7/8[/SIZE][/COLO
Features:
[/B]
Diameter : 320mm
Thickness : 32mm
5Holes
Diameter : 300mm
Thickness : 22mm
5Holes
Front+Rear = RM3400
COD JB/Malacca
[/QUOTE]
bro, do u have for Toyota Caldina GT-Four? Front only
I dunno :hmmmm:whether got ask b4, have u got that suits LancerGT?
