is there any low compression piston that can fit into myvi engine?
yrv piston can fit?
need to bore the block?
yrv piston can fit?
k3-vet piston = 72mm no need bore
starlet 2E piston = 73mm ..need bore.
both also low comp piston..good for boosting.
ok thanx bro..isit easy to find starlet piston nowadys?
i dont think it is that difficult bro...still can find those pistons.just need to look around
Starlet is 1.3 for 4E and 2E if not mistaken ... I myself have tested starlet 2E turbo pistons on a 1.0 kelisa block with L2 head ... i've boosted up to 2.7 - 2.9 bar with no problems ... provided ur fuel and ignition is sufficient :)
was able to make 270++whp ... :)
i doubt that u will be able to find 2nd hand 2E turbo pistons nowadays cause its quite rare ... brand new cost around RM700 same with yrv piston also ...
Trust me on this when i say that BOT ur myvi will cost more than a YRV halfcut .. might as well buy a halfcut and dump it in and keep ur engine as spare ... :) reliability is there and its better to start off with :)
Happy Boosting ... :)
bro if wan 2 change oversize piston wat is da maximum sizes can bore ah?
eg. std size 78.4mm?
Maximum extra 2mm... thats the limit... otherwise it will crack especially at high boost and long harsh driving...
Normally recommended is just 1mm oversize...... that is the safest zone.
sebastian...i tot v6tt is 79mm? 78.4 ka? same as L5 is it?
if wanna change oversize piston, u gonna change all 6 pistons ah?
of coz change all 6 piston la...
thrn can change a few only meh
so an1 know where got reliable for this piston bore ahh?
i've seen it
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not...
