It should be stamped on the housing. Or you can do a manual calculation by measuring the exhaust side diameter
any one know how much horse a T04E is capable of? and it is a good turbo?
Uh oh, just did a check and I am mistaken. They stamp the AR on the housing. I have no idea how you find out the trim unless you bought it that way. Will let you know if I find out.
Trim refers to the relationship between inducer of the compressor wheel against the exducer of the turbine wheel.
You can read more here:
http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech102.html
Your life would be easier if you had a Garrett turbo coz you can calculate the trim from the 4 digits.
---------- Post added at 02:22 AM ---------- Previous post was at 02:09 AM ----------
400, 460 and 490hp depending on the trim - 54mm, 57mm and 60mm respectively.
As for whether it is a good turbo, it really depends on your application. If you stick a big turbo on a small engine and get no boost, will you say that the turbo is bad?
The 2nd previous owner bought the turbo kit from a member in Melaka. Confirmed is TO4R.
Gah! T04R is maxes at 700HP.
Do you really need all that power? I think you would be able to get 400HP flywheel at 1bar for a rotary with the usual mods.
Right now I'm only running slightly above 300 at 0.8 bar. Will there be any issues with running that low boost? I have a boost controller which i can set to 1 bar, it that any different to having it re tuned to 1 bar?Question: How do you know you are putting out 300HP at 0.8 bar? And is that wheel HP or flywheel?
Assuming that 300 RWHP, it means that the flywheel is producing 375HP - with 20% loss at the wheel. That's pretty close to 400HP at the flywheel. Doesnt sound any problem to hit 400HP at the flywheel at 1 bar then.
