ECU Problem...Continue to read...
bung, pm me your address la... i wanna sent my fren single kambing vtec for u to check it... p73 i think...
---------- Post added at 12:26 PM ---------- 6 hour anti-bump limit - Previous post was at 12:23 PM ----------
Bro...
It is confirmed.... your capacitors have leaked and have damage areas near it.
Pls send for repairs and I will try to fix it back to normal....
Tq
---------- Post added at 10:16 PM ---------- 6 hour anti-bump limit - Previous post was at 09:56 PM ----------
Onconnect,
Here is my diagnostic based on ur pictures...
1. Your ecu is P08 auto & has been chipped with Thunder Chips.
(NO KNOCK BOARD)
2. Big cap C27 have leaked, nearby chip cap C72 maybe also spoilt.
3. IC14 surrounding areas also looks damaged...
4. Medium cap C34 alos have sign of leak.
5. Bottom side transistor for injector control QM3 have sign of repair of copper trace...
Tq...
p/s u will soon have fuel and spark timing related problems or CEL code besides your current
vtec cannot crossover trouble....
I am quite confident it can be fixed.... Tq:adore:etech.
how much repair it??comfirm ok 1 ???
As mention in earlier post....max i can charge is RM250 (half price of a std ecu)
Your case is chipped ecu, so have to be RM300..
To others Honda owners.... PLS CHANGE YOUR CAPACITORS BEFORE IT LEAKS... It will be cheaper and cause u less headache and heartache. Pls take this advise...
If someone can send me a FOC spoilt ecu, then I might be able to repair it and use it for exchange
program for those wanting to get their caps replace....Tq
P/s... i think will not work... cause those that seach for this thread, most probably ecu already rosak and looking for cure......:biggrin: Anyway prove me wrong okay....
haha.... did u get the ecu??? my fren kept mumbling2 over here....
** i wanna to solder my fren mouth..... aishhhhhhhhhh
Bro
after work I wil go to
workshop to check.
If can tonite I check and update u.
Sabar ye... Sebahagain dr keimanan...:biggrin:
Yaaang....
What was the penyakit of the ecu?:biggrin:
i think ecu terbakar la.....
my fren use p73 T00 then swap with other p73 t01... oso had same case... kebabo...
got burning smell......
Bro..
Btw ecu tak sampai lagi. Maybe today kah?
---------- Post added at 07:38 PM ---------- 6 hour anti-bump limit - Previous post was at 06:12 PM ----------
Oh ... Just arrived... bro sender is Mohd Hazdi.. inside is P27- honda single cam local... correct kah?...
ONCONNET bro,
Checked your P08 chipped ecu just now and worked on it for 2.5 hours...
All 7 capacitors have been changed. The big cap C27 confirm leaked and caused problem to the surrounding area...
I also found the reason why the vtec no crossover and have repaired it.
All should be okay now. I just need to put into a car and test before returning it to your... Lucky you, it could be save...
Anyway I attached some pictures for you and as WARNING o other also.
Tq
Another ECU saved!
Onconnect...
Tested the ecu, ...
Result.... check light off after 3 seconds- normal
started da engine.... normal
idling steady....
drove it...vtec can on..
Will pack and return to you asap. Tq:adore:
congrats bro.. :congrats:
will update you once my mech has confirmed what he wants to do with my old ecu....
