what to do bro, need to carry heavy stuff like welding machines n generators etc.... just hope it pairs well with my unser n e rear differential gear box.
Then at least won't kena bully by a lot of cars out there...but still your car body is heavy. So, resutls will be lower than performance cars. Just my point of view
IC...now i understand your means of modifiying your unser...not for performance m i right? Since you said, is your only daily car. I guess there is not much of a choice but to replace the engine. Put in 1JZ-GTE better since it is FR spec...surely better than 1g-gteThen at least won't kena bully by a lot of cars out there...but still your car body is heavy. So, resutls will be lower than performance cars. Just my point of view
Yeah BH is right. If you need load of torque to haul your loads, a 1UZ V8 should be a consideration. Anyway guys i think you should stop suggesting 4 cylinder turbo engines. Simply because the owner wants torque to haul goods in his Unser. Sure the SR20 & 3S is great and possibility of high HP too. But it lacks torque when compared to 6 cylinder engines. You should be thinking why all those hardcore off roaders would chose a 1J turbo over any 4 cylinder turbo engines? Oh yeah do extra bracing on the body for hauling heavy goods la. You don't want the goods to be left behind in a whole under the body!!
torque? v8 has plenty of it.. ahahah.. ANYTIME!
Never seen an unser breakdown b4 , not on the road i've travelled at least....i'm looking at MT so the power wise shd be ok... important is reliable not always breakdown.
