all 4g93 na owners out there!!!!!!
93na
hai alll just wan to know bout ur 4g93 na engine!!!
1) wat ur max speed and how bout ur 0 to 100km how fast u can hit!!!!!
just wan to know bout the monster of 4g93 out there!!!!!!
thanks
ex 4G93p owner can ah?
i used to drive a GTI.....mine not monster, everything std..
can easily hit 200kmh...., still can go further..cos mine is MMC ECU ma...
but telur x cukup besaq...haha..
can bro v all share share la!!!!! now u got a monster wat!!!
thanks bro
now not monster la....only in the making....
wang tarak cukup bro.....:(
hows your car doing bro? any new mods?
ok!!!
for me nothing la!!!! saving some cash also!!!!! JUST change all the engine maunting, bushing front and back!!!!!! normal wear and tear stuff la!!!!
---------- Post added at 04:46 PM ---------- 6 hour anti-bump limit - Previous post was at 04:45 PM ----------
0-100 8 sec, 220kmh
oh ok!!!! that fast!!!! on wat body bro!!!!! satria or wira!
yalor...better change the wear & tear parts 1st before u proceed with any mods....
of course satria la bro....c his avatar.
ok!!!
fast? not fast la...normal acceleration n top speed for sgti...
u using mmc or siemens ecu? should be mmc rite?
if siemens, rev cut at which rpm?
i'm using 4g93 auto from e52 body (mits lancer wagon)
had a few adjusment made with the valve body line pressure inside the gear box.
quite ok compare with 4g93 auto in putra. tested.
mine last time using 2000 model with mmc ecu...
i heard the siemens one cannot pakai...... got lower rev + speed cut.
mine putra 1st batch, with some mod.. can easily hit 220+ no rev cut :)
0-100=7secs flat...top speed=220-230 la...but dnt dare to push more...highest i got reach is 240...
management usin e-manage...high comp piston...lighten flywheel and crank..block blueprinted...port polish...super90 TB...tomei cams...HKS adj cam pulley...
jst sharing my baby's specs wit ya'll!
cheers!
thanks
0-100kmh unknow,top speed is 350kmh~if i want,ps:only block is 4g93 other all is other part..
cheers!
How much are you outputting on the wheels?
