Large Disc Brake for Myvi Help!!!
You can get it from half cut shops :) i got mine from another forumer but it's EK brakes which is similar with EG and I would say the brake really perform well :) but make sure you have at least 15" rims because it doesn't really fit well in 14" stock rim :)
Brother, i got the eg brake at chop shop. But the screw hole was different, where did u modify the bracket convert to myvi? mind to share?
bro, search at zth marketplace > chassis and wheel...
now they use wira disk to myvi knuckle with special spacer.. very got solution also...
Which screw hole??The 4 holes??? And how do you define different?
Not the screw to lock the wheel, is the caliper bracket at behind the disc rotor.
---------- Post added at 09:53 PM ---------- 6 hour anti-bump limit - Previous post was at 09:49 PM ----------
Bro, thanks for your advice, that product i saw it, its really works for certain problem. But my problem is the caliper, not the disc rotor.
I see...you need to do some threading work on your knuckle...happened to me last time, but when you bring it over to a workshop to install, they should have 'gaodim' all for you :) where are you installing it?
i do believe that there are ready made conversion brackets
fyi even u have the brackets..some edges of the EG brake supporting bracket will have to be shaved off
aiyo~ gombak area many place have try go Kepong Lama Jusco nearby de food court there got many car workshop~ my AE front disc and rx-7 rear also there install geh... so far so on mou man tai!!
