- Joined
- Jun 4, 2006
- Messages
- 2,798
- Points
- 1,683
wah lao bro you are Fu*king good in this !!!!!!
salute lah!!!
Lolx... dun mention... Effort of lifting hands...
keke... shy shy...
salute lah!!!
so the shim is small eh? kinda smaller that 5cents coin? like that eh? thx
It depends on which shims u wanna put. The one mentioned by tonytony or me.
If as tonytony mentioned, it's bigger than that. U locate it at the oil pump pressure release valve's spring.
For my case, it's about the size of a 5cents. I put 3, some put 2. Normally, put 1 doesn't make much difference.
at last, found dis thread, lol
so, around dis week, god willing, i'll conduct the process to get rid of dat tick-tacking noise in my engine. the methods iam planning to use is both suggested by members in here and the cleaning of the lifters themselves. i'll post the result here, if i remember ler. or else, members may pm me for the result
ya pls update us on the progressIt depends on which shims u wanna put. The one mentioned by tonytony or me.
bro.. can recommend anywhere to do this? or can we diy at my friends workshop? i belanja u nanti :proud:
some of my friends already did this a while ago, but i didn't managed to do it.
done, but not satisfactory. the sound decreased, but not as good as i expected. i was expecting the noise reduction wud be 100% because we used a thick washer jugek.
so, what we did was, we put a shim/washer which is around 2~3mm wide and plugged it in. i was worried if the pressure is just too much for the system? but by the sound of it, i dont think we exceeded the oil pressure the lube system cud handle. gonna do these things afterwards; a)change the washer thickness b)clean up the lifters
any comments are much appreciated
Lolz... So wad was ur friend's feedback...? Kkekeke..
so, i bought the cams+lifter and install it to my car... wallaaa... slience silence
ok lorr... sometimes only tik tik tik...
but yesterday got an offer by my foremen, which he has a spare putra complete head urgently to sell ..so, i bought the cams+lifter and install it to my car... wallaaa... slience silence
How much did he offered u?? Mind sharing???
tony, it needed time indeed. around a week after installation, it quitened down as if it is a new engine, the ticking sound just surface sekali sekala, but most of the time its quiet. i think dis is due to the used oil use, and the lifters are still clot wit hard carbon in it. iam still giving it time, watching it closely. so far, it really does what u told us, but not 100%. with ur statement about "giving it time", iam gonna give it a lil more time before going for the 2nd option; take out the lifters and clean them.
god willing tony, iam still monitoring it, showing good result thus far ni.. i think the ticking is still there sumtimes because, i reused the oil ler.. hehe, and the shim is around 2mm in thickness, is dat too much ke tony?
