The red blink like this...first blink about 2 second followed by 3 repeated blink and my check engine
light on.:hmmmm:
guys i got a very noob question here need to ask
i heard that emange got boost sensor function right?
is it come with it or it need additional harness?
what about map sensor? what is the function?
right now my emanage only got ignition harness only
sensor is additional. if u engine gt turbo or bot or bolt on s/c den nd a boost sensor to refine the tunning. if na, den no need buy boost sensor.
how much is the boost sensor bro?
and where can it be purchase?
this sensor is same as common greedy electronic boost meter. u can buy new or 2nd hand. most tunning shop oso have sell. price around 3xx. (few yrs ago n i m oso not sure the price for now coz now dun play this thing anymore).
oh yes ah. shit man i hardly see ppl selling in Zth..
tuning shop sure dam $$$
honestly speaking, if ur ecu comes with turbocharged mapping, there is no advantage of having the boost sensor except of being able to review it during the adjustment and view back of the curves...
Unless u're using profec b 2 where the boost can be controlled by the emanage. Even so, it's very depended on how good ur tuner is... And how well he knows what he is doing... And I heard emanage ult can get rid of the maf.. Heard only, not sure if it really works, since emanage ult is also a piggyback. Not sure if it could take full control of the injectors..
injector harness can add 2 sub injector n control by boost sensor. etc u can set high boost n low boost in ur turbo system. etc, wen low boost u set 0.9 n high boost set 1.5. so u can use 2 sub injector to inject fuel wen high boost .
oh means i can add another 2 more injector is it? but where can we install the injectors if wanna add extra?
Make sure it's installed by someone whom really know what he's doing...
the pipe( stainless steel) between trottle and intercooler.
lets clarify this, injector harness and sub-injector harness is 2 diff things.
if u use injector harness u only use back ur current injector and can modify the injector opening.
if u use sub-injector harness then it can control 2 xtra injector which u can put usually before the TB.
