ECU Problem...Continue to read...
eh bro...my mech said he can repair him self leh....so he keeping the ecu...sorry ah bro...
Bro
received... Ok, that is courier company responsibility.
Tested?...this is my responsibility!
How? Can start? Vtec can open?:biggrin:
not yet tested coz my fren got course this saturday and sunday...
maybe this monday he will tell n report to me....
Donate ur spoilted ecu and save another
Honda from extinct. U can reversed couirer
charge to me...
Help out ur hondarian...tq
hi bro n sifu vtec, i've checked my ecu its P08 n its seemed ok, i wanna change the capacitor as advised, the problem is, the ecu is somehow very tight and canot be unplugged, pls advise, sori for the stupid question but its do happen
confirm can unplug bro...just need to hold the clip down...there is a lever at the middle of the ECU socket...you need to hold/push the lever down and pull out at the same time.....with some force..
Bro
tight means virgin.
Grip wires with one hand, press da clip wit tumb and
shake it out...
Or press clip wit one hand and da other hand wit screw drive
in the slot and push it out. The left hand continue to pull..
Ok?:biggrin:
:rofl: rofl: bro e-tech...that sounds turning on..maybe i should check my "ECU" too :rofl:
AD... your still virgin meh?
I think yours kena "rape" oledi- got superchip, changed caps, plug in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out and in and out...where got virgin still...
:biggrin::biggrin::biggrin:
Bro,
Can i have your contact number? My location is at JB.
I got two apexi power fc in hand now, both got problem, dunno whether can repair or not..
call me if u are intersted to fix it or sms your hp number then i will contact u.
0167363080
Terence.
Terence bro....
Me in muar....
If want then post to me with the problem
clearly labelled on da units....
Worst case try to make 2 no good units to
become 1 good unit....
Tq....
Btw...spoilted due to wrong wiring?
Tq
Reminder....seen to many of these
already...be safe and check ur ecu....
bro.. how to disable auto function in p30 without rechip? and how to remove solder inside hole (on board, 27pin to put socket).. that is default by factory in my p30..
Surely by "soldering"....
All this info are available in the net...
iF WANt to DIY.... must go seach and learn like me....
If lazy.... send it to expert...tq
If really want help mail me.... if mood good i take you thru step by step...
ok. Tq
ok. Tq
hehehe... last on 2006 i all ready do on my p28, desolder all the tin and rechip..
when i got change to p30 and the external ic is quite into the middle position, it quite hard to desolder..hahaha..
since you already met many type of ecu and facing many prob, so i assume ur expert.. my question is how to disable auto function in p30, beside rechip?
thanks for reply my question..
Just replace the RP18 resistor to 1.5k resistor its will work fine
