Can a stock evo3 engine withstand 1.5bar of boost?
spuzzle
Kuantan / Perth
all sifus,
can a stock evo3 block withstand 1.3-1.5bar of boost?
simple mod done:
18g turbo
e6x ecu
260 cam
560 cc injector
walbro
fuel regulator
banana
wastegate
metal gasket ( what thickness the best? )
target to achieve +-350whp
not advisable. evo3 with stock internal should only boost up to 1 bar max.
mine is evo2 stock internal. still alive after several spike to 1.6bar but i only run it max at 1.2bar. better to be safe than sorry. 1.2 bar is max for evo2.
evo2 can boost higher than evo3 with stock internal as evo2 has lower compression.
---------- Post added at 03:03 AM ---------- 6 hour anti-bump limit - Previous post was at 02:59 AM ----------
nevertheless, i met people that run more than 1.2 bar on evo1/2/3 and their engine is still running fine after several years of abuse.
they said that with proper fueling and tuning, 4g63t (stock internal) can withstand boost more than 1.2 bar without any problem.
some calls 4g63t bulletproof engine... some calls it 'tauhu'.
when talking about boost, we also need to consider what turbo, because 1.5bar with td05 compare with 1.5bar gt35, is like comparing orange with apple..
in ur case spuzzle, u use 18g right? I think ur engine can withstand but all depend on ur tuning.. But still, evo block lot more fragile then vr4, some of them run 400hp in evo block still ok but many of them broke evo block when past 300hp...
anyway, before this I boost 1.5bar with tdo5 in evo 2 block, hantam kaw2, block still ok, just piston goyang already, cylinder wall scratch and the best things, crankwalk :wavey:
Boost won't break your engine nor cause crank walk.
Detonation and pre-ignition does, so avoid it like you avoid a $5 hooker.
bro paranoid can explain a little bit more why same boost level 1.5 bar but with different type of turbo size it will be different? bcoz i've been thinking if same boost pressure would mean it's similar at the end rite? i just upgraded to bigger turbo size but still using the same boost value as previous size turbo. I was thinking what would i need to reset so that the engine not kebaboom due to differences that exist now.
kanan, changing the turbine doesnt help much if rest of ur equits cant get along with ur td04(sufficient enaf to support)
crankwalk? wat does it mean and what causes it?
bro, u r in the toyota world, maybe that word is strange to u kekeke
mitsubishi evo blocks has a manufacturing defact , freeplay of the crankshaft which causes wear of the thrust bearing, then gone
i also tot that 1.5 bar of pressure will be the same using wat ever type of turbo. the efficiency island is different though.
u should select turbo size according to your airflow needs and application (e.g. drag/rally/track).
thanks to all feedbacks
kanan, bigger turbo more flow eventhough same pressure...so it is different at the end
So, why everybody afraid of the boost? is it because of the higher pressure or higher flow?
the reason why jin among the 6 bolts worshiper..hehehehe :burnout:
nevertheless, 4g63t is still a legendary engine, ;-).
engine purposely built for rally. not many engine can claims the same.
fuyoo jin 6bolts worshipper, hehehehe.. 6boltonly gang...
---------- Post added at 05:25 PM ---------- 6 hour anti-bump limit - Previous post was at 05:02 PM ----------
u have to tune back your car bro and see whether your AFR is good enough.. When change to bigger turbine, your turbo flow more and make more air, therefore u need more fuel to compensate with it.. I'm not that good in explaining but I hope u get what I mean.. Bro Jo1 please correct me if I'm wrong :hmmmm:
all sifus,
simple mod done:
18g turbo
e6x ecu
260 cam
560 cc injector
walbro
fuel regulator
banana
wastegate
Haltech E6X can control its...But be careful for your Stock piston bcoz thats also used for few years by JAPANESE...:biggrin:
all sifus,
simple mod done:
18g turbo
e6x ecu
260 cam
560 cc injector
walbro
fuel regulator
banana
wastegate
the evo123 piston ring and con rod and stud is really lame,need change that for safe,or u can run 10.0 a/f ratio for 1.2 bar,but also scare the piston will go out from your muffler ~
