- Joined
- Jun 4, 2006
- Messages
- 2,798
- Points
- 1,683
i would say higher pressure more risky...therefore i ask before i boost...hehe
It's the flow + pressure. Boost pressure is just a precompression of the air before it is recompressed in you cylinders. BUt of course, different fuel have different thermal property.
IF u have a high pressure but small flow turbo, example u boosting at 2bars with TD04L on an E3, the turbo chocks before 4krpm. When u boost 3 bars with the turbo, still the air is insufficient to fill your cylinder due to low cfm.
Example, I have my BOT with TD04L once tuned to boost 1 bar. Now, I'm on GT2560R boost ing at 0.6bar and I have white plugs.... Heheh....
yes i got what you mean bro. thanks
Hmmm... good good....
Haltech E6X can control its...But be careful for your Stock piston bcoz thats also used for few years by JAPANESE...![]()
True, we don't know how the engine was driven before us... E3 discontinued in 1996. Which means the newest E3 engine available is 13 years back.
However, if u take a look at kedai potong... Almost 90% of the Evos are kept standard and low mileage... They're fine...
Back to the thread starter... To my experience, it's safe to boost 1.2-1.3. bars with stock internals if TUNED WELL... The ignition timing is a little aggressive and higher CR compare to its precedor E1-E2. So, it's more risky to boost hight.
If u can avoid lean AFR and premature detonation, then things will work fine.
