Temujin, how did u find out u had those problems beside low oil pressure? any other symptoms?
Temujin ...could do a favor for me?After you take out the engine bearing and conrod bearing give me
the designated parts no on the bearing following by piston arrangement.
Then also no printed on crankshaft and top engine block..... :)
So L**** do hanky panky job huh?
bad reputation for such a nice company! haha.
I think I could get the no for the engine and conrod bearing provided it's still lying there.. but following piston arrangement a bit hard bro.. it's everywhere in the box of failed bearings hehe.. I'll try though..
Will get back to u with those numbers on Monday as we're having a long weekend![]()
Hahaha ok, bit unfortunate..... if not can analyze the cause of bearing failure....might on your bearing itself or crankshaft.
Anyway just give the code,myb i can give you the answer.
Yes im totally agree with Rakzakzsa...and also the important thing to take care is the Oil engine. Last time im using Torco oil but I realize that the oil is thin and become lesser when regularly drive. So I do research what is the suitable oil for the GTR engine. And lots of GTR owner said that they are using castrol egde. So I did try the said oil and it’s proved. Till now im using the said oil...but recently I quite grotesque why my oil pressure is low. When I warm up the engine, supposedly the oil pressure indicator show at the middle of the meter but now one bar fall. Any idea or advise? Do your car have a same reading?
Just FYI, some of the crank bearings were falling off the block instead of supposedly seated nicely during removal of the crankshaft..
Was told by the mech that the crank (and the block too perhaps) had gone off balance resulting in shot bearings..
Anyways, will go to the shop to get those numbers for you.. Cheers bro![]()
if the bearings is not seated properly when u remove the crank most probably you have bend your crank due to insufficient oil to lubricate the bearing n crank or oil temp is too high.. so i think you have to look into those 2 area first to prevent it happening again
My 32R had low oil pressure upon warm up, around 1 bar or slightly less. The oil pressure continued to go lower after a few days hence prompted me to send the car to the shop.
In my case, I think the oil pump was on its way out as it wasn't documented if the pump had been changed before. I assumed it still was using the original pump ever since it came out of the factory in 1991.
don't rely on the stock oil press gauge on the dash bro.. mine also show low oil press all the time like yours.. i think the sensor has kaput after 20 years hehe.. now i've install aftermarket oil press meter after i blew my engine similarly like what happen to yours and only now i can see my oil press showing 4-8 bar of oil pressure when driving where the stock oil press gauge show 2-3bar.. upon warm up my stock oil press gauge show 1-2 bar (sometime lower) and my aftermarket oil press gauge show 6-7 bar consistently.. when idle after engine is warm the aftermarket gauge consistently show 3-4 bar where the stock gauge shows 1-2bar (sometime lower).. morale of the story is dont trust your stock oil press gauge since our car is too old alredy heheh
