Battery Issue
loose_end
Malaysia
On the 27/4/2010 , My battery ( Maintainance Free ) went flat due to "turn on" of headlamp and foglight the following night . Therefore , I change to a new battery ( Maintainance Free ) on the same day .
However , on the 3th of July , when I send my car to the workshop for some repairing , the worker on the headlamp light and radio without starting the car . This had result where my car couldn't start and need to "jump start" in order to start the car .
Then , as I got home , I tried to start the again but I couldn't and need to "jump start" and I left the car running for 30 minutes ( assuming it could re-charge the car battery ) . Then , I tried again and the car started and I tried it for 3 times . Everything went well.
The next day , 4th of July , I couldn't start my car , I didn't bother about "jump start" it anymore
So today , I send my car to the workshop and got a checked but was told it was the battery issue . Then , I went back to the shop where I previously got my battery from ( 27/4/2010 ) to get it checked and got a new replacement since it was under warranty.
In conclusion , my question are .. Could my car cause the battery to went faulty ? What other causes should I look for ? ( Fyi : I am running on 2 amplifiers and a pair for fog light with 2 bulb each ( total 4 bulb )
perhaps the alternator, bro? sometimes if the when alternator almost dead, it couldn't generate enough current, it drain the battery current until flat, used to happened to my wira. Change to new battery or recharge battery also result the same, car couldn't get started the next time I want to use it :mad:
Yeah , was told by the foreman just now .. He said the alternator got no problem
