SF...dynamat is like those butyl mats that u stick onto the inner side of the door sheet metal. it'll make yr door metal thicker(in a way) and have a lower resonance frequency...imagine if u drop a piece of door sheet metal on the floor...will sound like *KLANG KLING KLONG* rite? now imagine if u stick something like a piece of rubber mat all over the door sheet metal and drop it on the floor...it'll sound like *THUD* cos the metal now is thicker n more solid mah. as far as i know, dynamat xtreme is the best and a box will cost about rm800-rm900 and should be enough for 4 doors. not sure what exactly is made out of but should be something like butyl...imagine thick thick tar?
the door rubber i was talking about is the rubber lining around the door edges to prevent water from coming in mah...the older the car, the less supple(remember the baby bumbum?) it gets loh...so the older the car, the more it sounds like tank door closing. if u ever noticed...new cars always have that *WHOOOMP* sound when close door....but old cars almost always have that *KA KLANG* sound when close door mah.
also no need worry about sticky mess the tapes leave behind...spray a little WD-40 on it..leave it a while then use yr fingernail to scrape it off....then use soap water to wash off the WD-40...kautim! any sticky mess left behind WD-40 oso can clean off...reminds me of 1 time...i drove over a chewing guy rite at the edge of my tyre....then the gum still fresh out of the mouth *yuck* so u can imagine the mess it made...the whole side of my car splattered with gum...my rims all kena and my tyre well all kena...sprayed WD-40 and wiped off slowly then wash off with soap water...no mess left at all...
and now to the most important part...the mini skirts...my fetish ler...u dun la remind me of mini skirts early early in the morning...summore is friday. a lot of miniskirts running around here ler. die la how to concentrate la now....
Danz...sori yah but when i accidentaly read yr post as
. later u go home...u open yr car door wide wide...then u look at the under side of yr door...see can find some holes at the bottom or not...thats the drain holes loh. but then...i'm basing this on my car la...maybe new cars have different methods of draining the water out so dun go drill a hole if yr car no hole ar
you are really entertained me a lot today
