im using it..... tat's a hose connected to ur internal actuator....
tap from there....
tanks dude, but i'm using tial external waste gate, it is ok to use original air filter for up boost? help
)*wanna ask info on tulang-ikan (aquarium oxygen valve)
-the orientation to install which position???? is it sandwiched between wastegate and boos pressure????
or is it install using "T" which leaks boost pressure to atmosphere before going to wastegate??
No need T. The tulang ikan valve is already bleeding pressure to the ATM.
From wastegate / actuator got one hole there, put the vacuum hose there and join the tulang ikan in the middle of the vacuum hose, and continue the hose to the intercooler piping (make one hole there near to t.body, after the B.O.V. holes)
Please top up some more if my explanation is not clear..hehe.![]()
haha...ok..noted that....
Works Manual Boost Controller ok ka if to play higher boost (up to 1.5 bar)?
Currently using fish bone (tulang ikan), not really accurate, still searching for another manual boost controller that cheaper...
p/s: If got budget wanna buy Greddy Profec-B II, huhu. But for now manual boost controller is the best option. (no money no higher boosting..)
there is a hose from the exhaust manifold connected to the actuator, T-bridge it, using the 3 valve tulang ikan, keep the valve open by 1.5, and the 3rd one closed. this will give about 0.8 bar boost to ur stock turbo
errr...2different answer....
i guess both way boost still can be adjusted rite???
