Hi Guys,
This morning, my car engine light was on. Performance and rpm dropped until engine stalled. Tried couple of times to start. Yes, can start. But once i lifted foot from gas pedal, engine stalled again. Removed batt terminal to reset ecu but still the same. End up went to workshop and one forman helped me to diagnosed. Error code was air intake/vacum sensor abnormal. What forman has did
1) Swapped map sensor. Result still same.
2) Checked map sensor hose, no hole or leaking.
3) Swapped TPS sensor. Result still same.
4) End up, he used air gun blew map sensor hose that is conencted to throttle body. Check light dint showed, but rev 5-10 times, light on again and engine stalled.
5) The last thing he did was changed below item which i marked in orange color. I duno what this thing call. From workshop until now, so far so good.
After all, he told me it could be my throttle body or the part on top of injectors there dirty. He suggested me take everything out to do cleaning and the labour is Rm250. Is this the usual price? Somehow until now,i still not convince and the problem might come back. I checked on bro Chin website, but couldnt find this intake/vacum sensor.
Guys, any suggestion on this? Urgent need help here. Thx.
. pmed you.
