Runstop Curve Slot Disc Rotor
MM-Marketing
Runstop (Oversize/Standard) Curve Slot Disc Rotor
Warranty:1 Year or 20K KM
Item condition:Brand New
Dealing method:C&C or Installation Provided
Contact method/details:0168261755
M o F #1 Slotting of standard disc is recommended to improve braking
Myth #1
Slotting of standard disc NOT designed to be slotted causes various problems; vibrations of disc due to unbalanced removal of material, the slotting and removal of disc material weakens the disc structure and rigidity, pre-mature disc material fatigue may result causing warping and cracking. Safety is thus compromised.
All RunStop curve slot disc were designed ground up with the correct internal vane design, disc materal thickness and stronger material selection to ensure the strength and rigidity of the disc to withstand the heat and stress of repeated braking.
RunStop vs standard disc
Top is RunStop curve slot disc, bottom is standard disc. Note RunStop curve slot disc internal vanes are much thicker, closer pitch and disc has has been selected and designed for curve slot
M o F #2 After rear drum to disc conversion, the handbrake will not work properly
Myth #2
Our rear drum to disc conversion is designed and customised for the Jazz / Fit, all parts used are Brand new which come with Brand new brake shoes & brake pads. After installation we also ensure that both the foot brake and hand brake work properly before handing the car over to the owner. We have come across several cars with strange combinations of drum to disc conversion using parts from old Civics and parts from scrap yard where the handbrake does not work properly. We recommend a proper custom job instead of mix-and-match-combination. Safety is key.
M o F #3 Braking will improve upgrading from 262mm to 285mm disc
Myth #3
Increasing the disc diameter from 262 to 285mm will provide negligible braking improvement as the increase is too small to have significant brake torque increase, a measely 11mm increase of the caliper outwards is of small significance. The huge cost and work involved does not justify the negligible improvement. A simple economical upgrade would be to replace with RunStop curve slot OEM size 262mm disc; this would provide sufficient braking improvement for street use. A proper upgrade would be Pro II kit 314mm disc upgrade to have significant brake torque improvement, this set up requires minimum 16"
NANO pads are here after much positive feedback from our customers
These are high performance NAO; Organic pads that are low dust. Those that hate noise & brake dust and have white or beautiful chrome rims will like these pads.
The pads have a typical of 0.4 mu (peak 0.43) rated till 600C, extremely consistent brake pad behaviour. Very suitable for street use as they do not need warm up and occassional weekend track warrior.
As you can see from the chart, most pads start to fall off drastically from 300C onwrads but our NANO maintain their braking torque till 600C
Note the 'white-ish' brake dust after a Sepang track day and 1500kms w/o washing the car
Here are some of the photos of other car maker:
http://img535.imageshack.us/img535/603/stockaltis6610427.jpgAltis
http://img25.imageshack.us/img25/8743/front6622147.jpgCivic VTI
http://img821.imageshack.us/img821/9463/front3286633402.jpgBMW E36 Front
http://img156.imageshack.us/img156/8830/rear2806643961.jpgBMW E36 Rear
http://img156.imageshack.us/img156/6112/front285in166691785.jpgOld Honda City Front 285mm
http://img25.imageshack.us/img25/9981/front6713092.jpgSuzuki Swift
http://img130.imageshack.us/img130/8199/frontlatio6723345.jpgNissan Latio
http://img59.imageshack.us/img59/3130/front6741560.jpgHyundai Getz
http://img24.imageshack.us/img24/2463/front328in176665077.jpgCivic FD Front 328mm in 17"
http://img819.imageshack.us/img819/599/rear300in176678644.jpgCivic FD rear 300mm in 17"
http://img534.imageshack.us/img534/874/front2857955470.jpgJazz GD Front 285mm
http://img23.imageshack.us/img23/7889/rear285conversion796025.jpgJazz GD Rear Drum to Disc Conversion
http://img59.imageshack.us/img59/1342/front314in168059110.jpgJazz GE Front 314mm
http://img8.imageshack.us/img8/2897/rear300in168063459.jpgJazz GE Rear 300mm
http://img130.imageshack.us/img130/5527/front2856680696.jpgNew Vios Front
http://img156.imageshack.us/img156/3615/rear285conversion668916.jpgNew Vios Rear Drum to Disc Conversion
Please feel free to contact me to enquire for other car makers which is not listed above.
Special Promotion from 16 July - 31 August 2010. Deposit which is 10% of total price is required upon confirmation. Deposit received in the above mentioned period will enjoy the promotion price.
Civic FD2
Front 282/Rear 260 - RM1100 (normal price RM1250)
Front 282 + Rear 260 - RM1650 (normal price RM2050)
Front upsize 328/Rear upsize 300 - RM1600 (normal price RM1950)
Front upsize 328 + Rear upsize 300 - RM2800 (normal price RM3350)
Jazz GE/New City
Front stand/ard 262 - RM1000 (normal price 1150)
Front upsize 314/Rear upsize 300 - RM1300 (normal price 1500)
Front upsize 314 + Rear upsize 300 - RM2600 (normal price RM2900)
Jazz GD/Old City
Front standard 240 - RM950 (normal price RM1050)
Front upsize 285 - RM1200 (normal price RM1400)
Rear drum convert to disc - RM2500 (normal price RM3000)
Front upsize 285 + Rear drum convert to disc 285 - RM3700 (normal price RM4400)
Myvi
Other car makers do enjoy the promotion as well. Please put down your queries and I will come back to you as soon as possible.
Regards,
MM Marketing
Sole distributor of Runstop Curve Slot Disc rotor in whole Malaysia and Brunei
Sole distributor of Sonax, Broquet and Eco-V for East Malaysia and Brunei.
Free Nano brake pads (low dust formula and 600c) plus a dot 4 brake fluid with any disc rotor changed from now til 31st August 2010.
Don't miss this special offer...
Waja aftermarket curve slot disc rotor available for booking now
Front 256mm - RM1000 (normal price RM1150)
Rear 260mm - RM1000 (normal price RM1150)
Front + Rear = RM1950 from now til 31 August 2010.
http://www.facebook.com/home.php?#!/pages/MM-Marketing/145460135468059?ref=ts
Please join us in Facebook to see the feedbacks from users.
Another Belta from 255mm to 285mm.
Stock disc
http://a.imageshack.us/img714/4118/front2559566286.jpg
Adaptor being provided to extend the caliper
http://a.imageshack.us/img256/7541/newadaptor9572830.jpg
Runstop Curve Slot Front 285mm disc
http://a.imageshack.us/img340/9558/front285s9569782.jpg
I will be at KL on the 4 and 5th September. I only left 2 set of myvi 285mm disc rotor. Please SMS 0168261755 for booking now. Bracket and installation is included. Don't miss this very last set. Next shipment will be end of November.
GREAT NEWS for LATIO USERS!!!
We have came out with 285mm for Nissan Latio.
GREAT NEWS for BMW Z4 Users. We are here to introduce our Runstop Curve Slot 320mm for BMW Z4.
Here are the car models that we have:
TOYOTA
Old Toyota Vios/MRS Front - 255mm, 305mm, 320mm
Old Toyota Vios Rear - 269mm, 285mm(drum convert to disc)
New Toyota Vios Front - 255mm, 275mm, 285mm, 305mm, 320mm
New Toyota Vios Rear - 269mm, 285mm(drum convert to disc)
Yaris Front - 255mm, 285mm, 305mm, 320mm
Yaris Rear - 285mm(drum convert to disc)
Altis Front - 255mm, 305mm, 320mm
Altis Rear - 269mm
2008 Altis Front - 275mm, 320mm
2008 Altis Rear - 259mm
Old Camry Front - 255mm
Old Camry Rear - 269mm
2003 Camry Front - 275mm, 320mm
2003 Camry Rear - 288mm, 320mm
2007 Camry/Alphard Front - 296mm, 355mm
2007 Camry Rear - 281mm, 330mm
Avanza Front - 233mm(ventilated disc, stock disc is solid disc)
Innova Front - 282mm
Wish Front - 275mm, 324mm
Wish Rear - 288mm, 320mm
Celica Front - 275mm
Harrier Front - 296mm
Harrier Rear - 288mm
Rav4 Front - 302mm
Prado Front - 319mm
Prado Rear - 312mm
Land Cruiser 80 / LX450 Front - 311mm
Land Cruiser 80 / LX450 Rear - 335mm
Land Cruiser 100 / LX470 Front - 313mm
Land Cruiser 100 / LX470 Rear - 329.5mm
Hilux Vigo Front - 297mm, 330mm, 350mm
Hilux Vigo Rear - 350mm/320mm with 4 twin pot calipers, 350mm/320mm/295mm with 2 twin pot calipers, 320mm/295mm with 1 twin pot caliper
---------- Post added at 07:55 PM ---------- 6 hour anti-bump limit - Previous post was at 07:44 PM ----------
HONDA
Civic EG Front - 240mm
Civic EG Rear - 239mm
Civic EK Front - 262mm, 314mm, 320mm
Civic EK Rear - 239mm
Civic FD Front - 262mm, 282mm, 320mm, 328mm
Civic FD Rear - 260mm, 300mm
Civic EK9/Integra DC2R Front - 282mm
Civic EK9/Integra DC2R Rear - 260mm
Accord 1994/2000 Front - 260mm, 320mm
Accord 1994/2000 Rear - 260mm, 300mm
Accord 2003 Front - 282mm, 328mm
Accord 2003 Rear - 260mm, 300mm
Accord 2007 Front - 300mm,350mm
Accord 2007 Rear - 282mm, 330mm
Prelude BB2 Front - 282mm
Prelude BB2 Rear - 260mm
Jazz GD/Old City Front - 240mm, 285mm, 320mm
Jazz GD/Old City Rear - 285mm(drum convert to disc)
Jazz GE/New City Front - 262mm, 314mm, 320mm
Jazz GE/New City Rear - 300mm
Legend/Odyssey Front - 282mm
Legend/Odyssey Rear - 282mm
CRV 2002 Front - 282mm, 300mm
CRV 2002 Rear - 282mm
CRV 2007 Front - 297mm, 350mm
CRV 2007 Rear - 305mm, 330mm
---------- Post added at 08:02 PM ---------- 6 hour anti-bump limit - Previous post was at 07:55 PM ----------
PROTON
Wira 1.3/Satria 1.3 Front - 234mm
Wira 1.5/Satria 1.5/Persona 1.3/Persona 1.5 Front - 236mm
Wira 1.6/Satria 1.6/Satria 1.8/Persona 1.6 Front - 256mm, 320mm
Wira 1.6/Satria 1.6/Satria 1.8/Persona 1.8 Rear - 260mm
Waja Front - 256mm
Waja Rear - 260mm
Perdana Front - 256mm
Perdana Rear - 260mm
Gen 2 Front - 266mm, 320mm
Gen 2 Rear - 280mm
How much for bmw e46?
bro, what is the model? 318? 325? 328?
---------- Post added at 11:14 PM ---------- 6 hour anti-bump limit - Previous post was at 11:13 PM ----------
Walao... damn nice weih your rotors. Any nissan models bro?
bro, yes we have. Please wait a while while I'm doing the list
---------- Post added 08-25-2010 at 12:28 AM ---------- 6 hour anti-bump limit - Previous post was 08-24-2010 at 11:14 PM ----------
NISSAN
180SX Front - 280mm
180SX Rear - 258mm
200SX Front - 257mm
200SX Rear - 266mm
240SX Front - 257mm
240SX Rear - 258mm
Cefiro A31 Front - 250mm
Cefiro A32/A33 Front - 280mm
Cefiro A32/A33 Rear - 278mm
Cefiro A33 Front - 320mm
Frontier Front - 277mm
Sentra Front - 257mm, 320mm
Sentra Rear - 258mm
Skyline R32 Front - 296mm
Xtrail Front - 282mm
Xtrail Rear - 292mm
Latio Front - 240mm, 285mm
Teana 230JM Front - 296mm
Teana 230JM Rear - 291mm
---------- Post added at 12:29 AM ---------- 6 hour anti-bump limit - Previous post was at 12:28 AM ----------
PERODUA
Viva/Myvi Front - 285mm
Kembara Front - 273mm
Kancil/Kelisa/Kenari Front - 211mm
All right thanks for the speedy response bro. Any 4 lug pcd100? Trying my luck... :hmmmm:
