- Joined
- Apr 17, 2006
- Messages
- 163
- Points
- 1,518
SVT...
engine die at idling...
common issue...
1) check for vacumm leak...Throttle body hose...between AFM and Plenum...that big rubber hose sometimes got cracks thus engine idle when crazy...if it's not there...look for others vacum hose...or loosen one...
2) then check AFM pin connector...unplug it...check the pin...dust of some of the dust...connects it back, make sure gor "click" sound when connect to it...
3) ISCV clogging...perhaps...
check out this link :
http://4age20v.blogsome.com/2008/03/21/diy-how-to-clean-4age-20v-iscv/
4) check for any existing error code...if none...try to reset it...as sometimes the ECU need to be refreshes up...
Good Luck on the findings...
5) Check you ECU...kindly swap with others...or contact the person above me... :D :D
my car was send to goodspeed( ah choy) at kepong to service my throttle body..it take off piece by piece to clean it up and oso clean ISCV..ECU pula was change with doctor ECU u mention it! person above u :hmmmm:...but problem oso same!
