- Joined
- Mar 3, 2005
- Messages
- 8,205
- Points
- 5,213
BCR, try the hose suggested by speed2horizon. The hose with spring coiled inside. I'm using it for my OCT also but mine is clear type. I bought it at hardware shop but it's less expendable so you will need quite some force to fit it and clamp it.
For my setup I just connect 1 hose from the cam cover to the OCT then the return hose I just drain it and not back to the intake. Inside the OCT I put in a lot of metal washing sponge..it's like those metal coil from engineering shop when they machined stuff. I use that to increased the area for the oil vapor to condense and to make sure the oil vapor is not escaping the OCT too fast. Previously before I put in those metal sponge, I can see oil vapor coming out from the outlet of the OCT. So I thought can put something into the OCT like a filter to trap the vapor.
