just remove front differential ... welding inside center diff.. plug driveshaft hole.... settle.... but it just theory.. i never done it also... but cannot remove the viscous coupler lah, if not the rear output shaft will tercabut.... huhuhu
owh sorry.... i tot u wanna lock it to RWD.... huhu..
humm.. wanna lock to FWD ... evo 4 gear?? still no experience.. if you have gearbox diagram, maybe i can help.... the internal maybe almost same with evo3 gear....
thanks for da sweet reply ~
actually is almost the same compare e3 and e4 gearbox , its just it is "terbalik" style
i have the Mitsubishi Original Manual Gearbox Diagram , Overhaul Manuals in pdf form
http://www.mirage-performance.com/tech/Manuals/Evolution%20Manuals/
but it is quite large if u download them all
would you mind if i send you the gearbox manuals so that you could offer me a help ?
No, this is not a sped up video, not even at 1.25 times.
This is the onboard footage of this year's fastest Pikes Peak run, where a Norma M20 RD Limited Spec-2016 driven by LeMans-winning Porsche 919 Hybrid...
hi guys i am a newbie here in the club. i would like to know. i saw an GTR34 mspec nur with red engine cover and silver colour vin plate. is it a genuine mspec nur? the chasis start with 403*****.
