[WT Ask] About High CamShaft - FUNCTION?
szeeonn
all sifu , whats da main function / purpose for high Camshaft ?
is it a NEED for Racing car ? for TURBO car ? gets more power ?
i wonder get more power = uses more fuel as well ?
thanks u
Simple explanation.
Increase the opening duration so that more air can be vented into the combustion chamber and extract from the combustion chamber. There are different specs of highcams. And also, high cams for turbo and NA have different Cam profile.
Not necessary for a racing car only. It can be used for daily driven to improve performance. Necessary of not depends on what U expect to extract from you engine.
Get more power will definitely consume more fuel on top end. But not necessary when cruising when the load of the engine is minimum on a Close throttle position. There are 3++WHP engine that will cruise for 400-500KM with RM85 of RON97 fuel.
It all depends on how ur tuner when he/she tune the car and what management to use.
BTW, an engine durability does not affect by how much pressure u induced. It's about how many HP ur engine/crank/conrod/piston can take.
There are tons of stock VR4 engine that burst within 1.5bars. But there are also some VR4 with stock internals that I know personally running on 2bars for daily driven achieving 36+ WHP. No problem at all. It all depends on what management u use and of course a good tuner.
speed2horizon , great explanation you have there
can i ask, is there a few type high cam in market ?
race cam ? street cam ?
i heard that would effect idling timing , is it ?
Yes, there are several type. In my shallow knowledge, I only know of 3. Conventional cast iron cams, billet cams and regrind.
Race cams or street cams. They are the same. Just different specification. Different duration will have different effective powerband. It depends on different individual in ability to accept it on street.
And yes, hicam will definitely affect the timing. Simple, ur lungs tries to expand to take more air, but u restrict ur nose opening. Effect is, u'll pull harder. In engine, ur duration is longer and valve lift is higher, but u remain close throttle, so engine feels like wanna stall. In order to prevent stalling, u allow more air by adjusting the idle valve. Result is higher idle rpm.
pro giving pro reply ~
wish to ask u more about cam thing
and engine thing if u dun mind ^^
Simple explanation.
speed2horizon, you said there are different highcams for NA and turbo? Can you please explain what is the difference please? I thought it is the same as the function is just to allow higher duration and lift for top end power. Why NA and turbo need difference profile highcams?
I plan to have a Blacktop turbo in the next 5 years. Slowly... So I think it' be better to get some advice from you now. I want to use blacktop over the 16V or 4AFE because I do not want to lose the low-end torque and fuel economy when driving in city. Since you said NA and turbo got different highcam, does this mean that the stock high cam lobes on the blacktop cannot be used if I want to turbo it? Please advice... Thank you.
This is what happened. BTDC setting, the NA cams have overlapping for the following purpose.
1) To cool down the pistons crown that's right after combustion.
2) To allow combustion chamber to achieve atmospheric pressure to allow free flow during the overlapping duration.
The higher duration the cams have, the higher overlapping occur....
For turbo cams, they doesn't have overlapping on stock. even for Evo. Reason is...
1) To prevent boost leak during the overlapping at low flow condition.
But when high boost, then u may allow some overlapping provided the turbo is able to produce the flow and pressure even if there's overlapping, then that's a good thing...
Too bad this thing will never happen during low boost condition. So, low boost will lose some pressure.
is best to use a high degree cams, the pair with the Haltech hehe
As long as it's tuned and set well... No specific brand of standalone.
But high cams for street use.. The question is always HOW HIGH??? If u gonna plonk in 308º CAMS as street use on heavy traffic roads like KL...
normally have to look at the settings and hardware compatibility of the vehicle itself to daily use ... much easier if there is good management and tuner
base on my experiance, please correct my statement if there is wrong
Hmm... Management wise, it's more for ISC, ICV, etc.... Cam correction setting... So that u'll have a better idle.
I'd say anythnig below 270 is nice for street.
yes...yes....it's true.......hahahaha
---------- Post added at 12:22 PM ---------- 6 hour anti-bump limit - Previous post was at 12:13 PM ----------
if u want more power in ur engine,comfirm FC is much higher than stock..i'm no SIFU,but that is the rule..now i'm using 300deg cam with 11' lift..hoooliowwww...FC is bad and not street wise..but i'm stick with it..why??coz power lorr...great power gain more fuel..even u using haltech or motec or microtech..it still use the same rule..but all this managemnt help a lot la..anyway,can try watermethanol injection..i never tried it yet..but really want to..i have see the result for turbo car...for NA not yet..have been that it could help reduce FC..
---------- Post added at 01:15 PM ---------- 6 hour anti-bump limit - Previous post was at 12:22 PM ----------
yup...that right bro...i agree that
---------- Post added at 06:08 PM ---------- 6 hour anti-bump limit - Previous post was at 06:04 PM ----------
If interested, fc is used to michine ok ... the original power and satisfaction achieved
Oh yes thank you! Now I'm clear... So you are saying for turbo, the high cams may have higher duration and lift but they try to minimize the overlap is it?
And you are saying that if there is overlapping in turbo, the pressure in the intake manifold will force fresh air & fuel right into the exhaust manifold during the overlap period right? Hmm... I guess this cause boost leak and will waste fuel...
So what to do if I would to turbo a blacktop? Any advice?
Methanol injection is a method not really to improve on fuel consumption. But to increase fuel efficiency. So indirectly, from better combustion effieciency, U are able to achieve more mileage.
Higher ignition timing produces better power, but the sad thing is when the ignition is advanced upt o a certain degree, it'll combust the fuel before TDC due to the over heated combustion chamber and the natural flash point of our pump fuel. That's knock.
So, when methanol injection takes place, it blends with the intake air to reduce the air temperature. Then it blends with the injected fuel to increase the octance level. By having a cooler intake and higher octane level, there u go... U can advance ur ignition further. And so, it produces better power.
At the same time, methanol injection took place within compressed air line... So, u'll have least worry that it'll damage the injectors internal and the diagphram of ur FPR.
---------- Post added at 07:25 PM ---------- 6 hour anti-bump limit - Previous post was at 07:16 PM ----------
I don't have much experience on BOT a blacktop... Cause black top memang highcam.. But not really alot la...
Okay, here is what u can do...
If u are boosting low, U can use adjustable cam gear to advance the exhaust cam and retard the intake cam. This can overcome the overlapping issue. Up to a certain stage.
Or, U can regrind the cams into a turbo cams. Send it to matspeed.
Or, U can change the pistons and straight go for high boost with a high flow turbo. On a high boost/flow application, overlapping is not a problem cause ur turbo is still able to supply the same pressure even though it's leaking.
hi there..
just to clear things a bit for me..i'm planning to run about 1.5~1.8bar of boost in a L2s engine..i've tuned my car before(on dynojet) and noticed that the tuner pushed until 7500rpm..since my turbo start spooling around 3500~4000rpm and achieve full boost around 5500~6000rpm,would there be any significant power change if i start playing with hi cam?can my engine handle more rpm than before?
not making my car to be a drag machine..just like it to be fun to drive on the street what kind of hi cam do you think that suit for my application?prefer the hi cam lift closer to my oem lift,would mild cam is enuff?can the oem valve train handle this kind of cams?
hi there..
Haha... The golden question is still, How much is enough..? Regarding on Rev limit, u can set it at whatever u like... It's the hardware that limits the safety margin of a machine...
high Rev causes valve float-counter with stronger valve springs
higher duration cams allow more flow at higher Rpms..
high rev also increase the stress of the conrod bearings. Using a better bearings will only make things slightly better... Custom rods and pistons make things safer... But at a costly price tag...
Able to make rev higher... Is your oiling system capable of delivering oil at that rate... Is your oil drainage to the sump have sufficient clearance to allow oil getting back to the reservoir to maintain the oil level in the sump..?
hi there..
What sort of turbine are you running? Theres no point you get a cam that can flow all the way to 8000rpm but your head can't and neither can the turbine bro. Where do you want the poweband to be at?:hmmmm:
