pifecto14 said:Hi Guys,
HOpe u guys can provide me wit some feedback, as now my car when driving at the speed of 120kph, at 5th gear the rpm is more than 4k rpm. Is that normal or wat?? I converted my car to manual as it use to be auto. Last time when i was at 120kph(auto), my rpm was around 3k+ rpm oni.
Hope u guys can tell me whether its normal and provide some advise.
Thank,
Regards.
kazami said:so muffler is together with exhaust ? i dun really know those part. Real life face to face teach is better than teach in the net. Net teaching = Confusing. Face 2 face= easier.
kl_dboy said:mine 100km/h is at 3k rpm and 120km/h is at 3.5k rpm... your manual gearbox is from wat car?
in this case i believe the car fuel consumption can be high...
cheers
pifecto14 said:Not sure from wat car exactly, but its the same with putra and satria gti's GB i was told. I retest it again just now, went up to 120kph, is at more than 3.5krpm for sure.
kl_dboy said:hi riggy,
thanks for the info... are u using koni adjustable or just absober? just curious if the koni got problem, where can we go for repair?
cheers
encikmasen said:r u sure it was from putra or satria gti? if 120kmh is more then 3.5k, i think its the 1.5 manual GB..check back with ur mech la..for me i cant give further comments cos driving with auto tranny..120kmh around 3k - 3.5k i guess..
riggy said:koni adjustables are the shock absorbers. If you mean COILOVERS, yes, i've modified the fronts to full coilovers with koni adjustable shocks, rear using the koni grooves to adjust the ride height together with a slightly stiffer spring.
Unfortunately for koni, no one seems to be able to service them as far as i know. but usually the konis should last at least 150,000km without problems. Mine has been going on strong for almost 80,000km.
regards
miveccom said:pls contact HWL marketing..heard that they can service any brand of adjustables..
I use APM Adjustables...apm is local co and they can service that thing..
reddice said:hye guys,
i have some problem with my car and hope that someone can explain what's the real problem..
yesterday,i was at mid valley,then when i wanna go back..
i start my car..then it start..but suddenly the engine die..
i noticed that the idle is zero...it does not stuck at 1K RPM..
so what happen actually??
i open the bonnet and just tighten all the connectors..and the car start..(maybe just a coincidence) but still not at 1K RPM..it drop until 200 to 300 RPM only..
can someone tell me why..but today..already ok....already at 1K rpm but sometime lower about 800-900RPM...
riggy,anything to say bro..
__________________
kl_dboy said:what would be your comment on APM adjustable? where u got it from? i hv narrowed down my choice to either APM or Koni adjustable...
cheers
