Better get the clutch fix. One thing about car problems that i notice, it is like a cancer. Start of small, and if it is not rectified, it will spread and this is where major damage is done. Better attack the culprit when it is young, small...
---------- Post added at 11:43 AM ---------- 6 hour anti-bump limit - Previous post was at 09:29 AM ----------
Just wana add here, is it ok if i set my Fuel Pressure Regulator to lets say, 45-46 psi? Or higher around 50 psi? Pump, injectors is all still stock..But according to the guy that did my dyno run the other day, my engine was running a bit lean,so had to increase the fuel pressure..Before this i set it at 42 psi.. And what is the correct way of setting it?Some say,the vacuum hose must be taken out,set the pressure then inserted back. And also after setting it back, the pressure gauge must be taken out..
