for 4g63t vr4/evo1-3 use back the perdana 4g63sohc mounting; if want 4WD use eterna rear diffs and shafts, and a custom long shaft (donno if the standard eterna ones will fit)
6A12 has SOHC, DOHC, Twin turbo, MIVEC and MIVEC MD variants. for the mivec find the one that looks similar to the perdana V6 engine (gearbox on driver side) and not the FTO or the later Galants version (gearbox on passenger side) then the engine mounts is the same.
Hi guys,
Did my first DIY sanding and polishing of headlamp for a friend. Posted here because of DIY and not in Auto Detailing because that one is sifu area....
This lamp was in really bad state, so he remove and...
Dear All,
I almost got cheated by a tire shop in Bangi, Malaysia. I will post more details when I m back to Singapore. Whoever is in Bangi now and wants to do tires or alignment, pls DO NOT go to the one that is...
