for 4g63t vr4/evo1-3 use back the perdana 4g63sohc mounting; if want 4WD use eterna rear diffs and shafts, and a custom long shaft (donno if the standard eterna ones will fit)
6A12 has SOHC, DOHC, Twin turbo, MIVEC and MIVEC MD variants. for the mivec find the one that looks similar to the perdana V6 engine (gearbox on driver side) and not the FTO or the later Galants version (gearbox on passenger side) then the engine mounts is the same.
Hi guys i want to turbocharge my satria 1.3 4g13
what size injector should i upgrade to?
and which is better e-manage blue or aem fuel ignition controller?
which turbo is more suitable for that engine? td04?
I am sure all of you will say Altezza. But I need to list some solid reasons (pls don't say if follow your feel, give me some points more concrete). I know they are different categories, but after discount back all...
