done dyno at William Trail, still not satisfy with the power output, will retry the tuning to hit above 160 on wheel...
Have you blueprint and balance the internals,if not then should try,u feel much smoother and response,also some power increase.
For more power,need to feed more air(change longer duration cams),bigger bore,higher rev cut (9000rpm is more than enough for street) and air fuel ratio tune/ignition timing tune..
last time mine afr 11.7...thanks
turbo?
Let say, 9k is best for street. What duration aftermarket cam is suitable for an optimize peak till 9000rpm?
the green le 20v laaa...not the my sr20 nissan...hehehe..but now le with with new setup, fuel set to very rich coz race in very hot afternoon...this setup very sedap during staging...hehehe
288 above...we see,Stock BT cam around 250 mark,already peak power near to 7k rpm...i would reckon with 288 it will drag peak power to 7.5k+ rpm region.
Cam timing plays a role too,in particular intake close and exhaust open point
Is it true, that if our rev limit quote]
I think the stock bottom is quite ok,everybody knows that Toyota block it is almost bullet proof..Be it 4AG,1J,2J...so i guess,just rev it to 9k without balance,cause toyota already balance in factory to certain tolerance(maybe not as tight as a race engine cause mass production).
If it doesnt broke,dont fix...but i suggest change the bearings to a better one.I would be more worried bout the valvetrain at such engine speed.
What is valvetrain?
