skullx
Hi guys,
Sorry for the long post.
As you may recall I had an issue with my Airtrek I posted here several months ago now where as around the time of replacing the intake for a pod filter, the engine only once at operating temperature would "hunt" between 1,700rpm and 2,000rpm when in that rev range (more noticeably when under load on an incline)
So pretty much in town driving at 50km it sounds like it is changing gears down and back up over and over, shuddering at times. Putting the car into tiptronic mode and keeping it in 4th gear makes no difference. Keeping the engine revs above 2000rpm and it's fine.
So far I have tried;
Disconnecting the battery to reset the ecu
Refitting the original airbox assembly
Checking all hoses and lines for leaks/loose connections
Trying a brand new aftermarket BOV
Cleaned all throttle body and intake pipes
Checked transmission oil level
I'm thinking it may be related to the MAF sensor as I damaged the Honeycomb grill when changing to the pod, I have since tried another second hand MAF I brought off the internet the grill turned out to still be damaged but no where near as bad as what I had done to my original one.
Any suggestions? Time to buy a brand new MAF sensor? Take it to the Garage?
Thanks Guys
Thanks Guys
