- Joined
- Oct 27, 2007
- Messages
- 821
- Points
- 1,543
i'm afraid emanage doesnt have speed cut removal function...it is more towards fine tuning your ecu...things like ignition timing, fuel injectors etc...RSM doesn't require a piggy back ecu to function...it will function if you install with/on oem ecu...
from what i know...JDM cars have 2 limitation (due to gentlemen agreement among the car makers)
1. is to limit power to 280 hp (i think...not too sure though)
2. is to limit speed to 180 km/h
these limiters are hard wired to their ecu...so long story make short...if you want to up the power you have to mod the mechanical things and the ecu (be it rechip,piggy back or stand alone)...if you want to remove the speed limiter...then you need the rsm...and both do not require one or another...it just common sense that why have more power if the car have a speed limiter... :P
---------- Post added at 10:08 AM ---------- 6 hour anti-bump limit - Previous post was at 10:02 AM ----------
simple answer is yes...with the right tuning and tuner...some people tune it for power...while other to improve their FC...me...i tune for my bt to run on ron 95 with minimal pinging...but sacrifice power a bit...
if we used the E-manage, the 4age 20v full tank can increase from 400km+++ till 500km+++...is that statement is true?:hmmmm:
