- Joined
- Mar 14, 2005
- Messages
- 39
- Points
- 3,006
Hi there, I baught this APM adj. for Integra
here's the specs for the coil springs:
FRONT 250/50 (around 3 fingers tyre to fender)
[attachmentid=43915]
REAR 250/40 (around 3.5 fingers tyre to fender)
[attachmentid=43916]
currently on 205/40/17.
is the above setup (coil springs) is recommended? i found out when hitting uneven road around 90-100km/h there's a loud "bummmmp" sound at the front. I suspect the coil springs gap on each other is too near. actually i already adjusted abit higher around 1/2 inch for the front.
is it possible to swap the rear 250/40 to the front?
I want both rear and front coil should look like the rear, the gap is wider. or it is consider normal for this adj coilover?
