- Joined
- Jan 26, 2006
- Messages
- 382
- Points
- 1,518
soo how to avoid the slipperyyy..? anyone.?
flatlander525 said:soo how to avoid the slipperyyy..? anyone.?
I used to shop with ebay..what i do is ask for the shipping cost first..but i only shop in small amount only and so far no tax..fzavier said:Hi there bros, need all your expert advise. I am looking forward to ordering some parts from the eBay located in US as they are not available locally. The cost of the parts are coming to USD 715 and will be delivered to my house address. What will the estimated tax imposed for this value here? Anyone knows, appreciate if you can advise. Many thanx bros.
azman_yazid said:actually B6t gbox and 626 1.6 gbox if you compare is very look alike ..you don't know which is b6t and 626 1.6 gbox..
many of us and also the mechanic are confuse about this..
the mechanic claimed it is b6t gbox but actually it is only 626 1.6gbox..
my friend bought b6t gbox (claimed to be b6t gbox) complete drive shaft about rm1600 and the when install, it is 626 1.6 gbox only..you will know it base on gear ratio..
i got one me B6t LSD gbox and 626 gbox, when compare the housing it's the same..
just 626 using clutch pump and the b6t using clutch cable..
ondgennis said:ya the B6T gb cause a lot of confusion. the sad case is there is no part number printed on the gb housing :(
ataro_gozambo said:Wahhh!! The Master has spoken.. If it was me who got the gbox.. cannot tell if it B6T or B6 DOCH NA. I know my current gbox is TX3 1.8 NA (was it?) ... but the 5th gear is shorter, 3000rpm only can go 85kmj in 5th gear. That was before I change to GTX 4WD 5th gear...
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not...
