VectorX2
how does affect to install a bigger car battery into a car? If batteries of bigger size but car engine starters of the same model would they be compatible?
i use two NS70 in my putra.... one at the front and another at the back..... alternator no kong also.
so got any bigger alternator that fits campro a? i am having problem starting my car everytime...
i am using a 46B24RS/N60S battery currently, what size should i change to?
. Perhaps wire up a direct wire from the battery to the starter for starters
weak cranking and need cranking for a long time only start, sometimes jerk at the starter
Check the grounding man. What people do is connect a direct live from the battery to the starter for direct current.
direct from battery to starter no la.. need fuse and/or relay one
can anyone give a hint...thanks...
