Sorry guys, i found that my messages won't appear in my first post in this thread. So i'm sending the same thing again n hope there will be no problem.
Hi Guys,
I am sure some of u guys ever experienced with a blown engine( apex seals/side seals etc..)
How do you guys detect if the engine is blown?
Or may be can be detected in terms of:
1-Idling behaviour
2-sounds
3-Does a blown engine still can produce boost like normal?
4- smoke from exhaust?
5-Or any other symptoms that u guys experienced with a blown engine?
In different case,
I am experiencing this kind of problems/matters lately(or is it really a problem and hope not)
1-I am experiencing weird idling during cold start.. hmm the trend is like..
RPM : 800 800 800 800 500 400 200 100, then kick to 1000 then 800 800
Sometimes the idle is as high as 1500 RPM during the first start even though the water temp has come to normal operating condition( 82-84 deg. C) and only came to normal 800-900 RPM after driven for a while.
Is it because of faulty TPS, bad spark plugs/ cables, or vacuum system?
2- When cold starting, I can obviously hear a mild * ting ting ting * noise from the engine at the turbo side sounds like steel pipes being hit together but not so loud... and disappears once the engine is warm.
3- I am using a Power FC and normally the knock reading will show highest peak reading of 20-24 when boosting.. Is this considered high?
Recently (yesterday), the knock reading surprisingly peaked at 64. I am guessing there was something wrong with the fuel system, could be the injectors/ fuel filter etc. or is it something to do with the mentioned problem 1 and 2 as stated above?
Power wise, I don’t feel enough G as before when the 2nd turbo kicks in, but the boost reading is still as normal as before.
Really need your help in tracing out and sharing experience regarding these problems dear sifus. I believe u guys have a lot of experience with rotary engine and the systems.
Just want to know more about troubleshooting these matters before sending the car to mechs. However I’ll send this car to Ah Choy this coming Monday to sought out these matters.
Thanks bros!!
Hi Guys,
1-Idling behaviour
2-sounds
In different case,
Thanks bros!!
