my friend using bt20V engine in his seg. when he the rpm reach 3k above, there's a sound coming out from valve cover. normally the tapet will giving sound but this one more louder. any recommend mechanic in seremban area?
Usually below 3000rpm its normal to have the diesel sound, but if half-throttle at below 3000rpm, the sound will disappear. If you are hearing sound above 3000rpm, then there's something wrong with the VVT pulley or maybe the engine is pinging (knocking). Knocking will sound like someone is knocking the engine with a screw driver.... LOL
hehe the sound will disappear and will apear again in some times.....
best way to test out is wit wat bro chinozie said ....unplug the VVT sensor cable ....then u test.....if problems still occur u try see ur distributor timing got lari or not lor .....
hello hello all my sifoo and RE frens its been a while i didnt post...
anyway i wanna make a survey about yall fuel cosumption.
i running everything stock turbine intercooler ecu all stock but my fuel...
wow!!!!what a race that was.i was hoping 4 the GTR 2 pull away from the NSX at the 2nd run but a mistake by the drift king at the final corner costs the NSX 2 get an undeserved win.well i guess that is a great day 4...
