my friend using bt20V engine in his seg. when he the rpm reach 3k above, there's a sound coming out from valve cover. normally the tapet will giving sound but this one more louder. any recommend mechanic in seremban area?
Usually below 3000rpm its normal to have the diesel sound, but if half-throttle at below 3000rpm, the sound will disappear. If you are hearing sound above 3000rpm, then there's something wrong with the VVT pulley or maybe the engine is pinging (knocking). Knocking will sound like someone is knocking the engine with a screw driver.... LOL
hehe the sound will disappear and will apear again in some times.....
best way to test out is wit wat bro chinozie said ....unplug the VVT sensor cable ....then u test.....if problems still occur u try see ur distributor timing got lari or not lor .....
Honda continues to expand in an effort to uphold its customer satisfaction as well as to meet the increasing market demand by unveiling its 59th showroom with a 3S...
hi guys,i am not mloc fans.last year i bought mitsubishi evo4 transplant with evo6 engine done by previous owner.after 8 month used in boost0.9bar i plan to do top overhaul and minor mod.after my mechanic take out...
