Can you even mix and match the pinion and crown like that? Don't they need to be lapped together etc? From what I've been told you can't...
Here in Oz we got either a 37/9 (4.111), 43/11 (3.909) or 41/10 (4.10). I've got all 3, am running the 41/10 at the moment. However my 37/9 is in very bad shape (or at least the crownwheel is), so I don't think you'll want it anyway.
And yes, you can buy those ratios. The first set of ratios from Palmside NZ (and I think the TRD ones are same ratio), and the second set from Albins in Oz. However, the 2nd set is not a standard Albins ratio, it was custom made. Should probably be available, but might be more expensive.
