here is my experience with BOV.
first BOV is SQV kit (2nd version without adjustable valve) for E7, no stalling initially till i put in more mods. Went back to ori and recirculate when started to experience stall issue. Finally opted for RS as it holds boost much better than ori bov (plastic). I removed the RS inner spring so that i can have better driving; dual spring is too stiff for boost under 1.5/1.6 bar, car flutters even when set to softest.
if u have the $$$, i would suggest getting the Greddy RS recirc kit then buy an extra VTA trumpet (around RM50); then do a test, if you can't VTA, recirc then. Or, you can buy the normal Greddy RS VTA (CT9A kit which comes with tapak) and custom make the recirc if need to recirc.
if you have an open pod air filter (apexi, knn or blitz), you can still hear the "woosh" sound when recirc but not as loud as VTA lah.
Hope this helps.
