I assume you are talking about the side. There is a bumper spacer, No. 17, on the body, white plastic thing. Make sure the spacer is still intact and the bumper is placed on the spacer properly.nashrey said:AGREED. no need 2 rush 2 get the 99 look if the finish is horrible.
Hikaru, my rear end had a soft nudge from an iswara recently, causing the bumper to expose a small 10mm gap between the bumper-body. how 2 rectify this?
You might alos wanna check the rear bumper support bracket, lift it up a bit to minimize the gap. The bracket is metal and it's just right underneath your tailight, the rear bumper should snug in there. Remove your bumper and lift the bracket up, then snug your bumper in and you might feel a bit tight once you lift the bracket up but it will fit just fine there.
http://www.hondaautomotiveparts.com/auto/jsp/mws/catimgs/13s041_b46.gif
