Differences btw DC2 and DC2 Type R
b18c5 said:
but u also can look at the rear end, the lower bar(dont knoe whats its really called la)... an ori dc2R, you can its just there factory installed....but if u convert u can never get back the same welding(so nice) as a factory weld.......malaysia technology not there yet hehe(if got also too damn expensive)
Bro,
Any idea where we can get that piece welded here?
Tegger-4-Life said:
Nobody knows the answer?
send it to workshop to do a compression test, then only u'll know if it's a b18c or b18cR.
3G Japan '95-'97 B18C 1797 10.6:1 178hp@7600/129ft/lbs@6200
3G Japan '95-'00 B18C 1797 11.0:1 197hp@8000/130ft/lbs@7500
and
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
Which is accurate?
they r the same: 178hp= 180ps, 197hp= 200ps.
juz wanna butt in a lil.....so the chassis codes are
dc2 gsr begins with 110xxxxx ??
dc2 R begins with 200xxxx?
can this information be confirmed...?? issit the same for both itr96 and itr98 specs? or any difference in engine chassis codes....
the aluminium lower boot bar is 35 inches in length front bolt to bolt. u cant have it weld as they were meant to bolt it by design.
zamnov said:
Bro,
J101,
Are you referring to the lower arm strut bar or the bar locared inside the rear boot? I still have that lower arm strut bar still lying around for a year now.
As for the one located in the rear boot, i already have that one installed.
yeap. the one the that hides near the boot lock.
zamnov said:
J101,
waa.... so many differences ar? come on. gather a few teggers and show the differences. i want to know too. i only know what's the differences between DC2 SiR-G II, DC2 type R '96 and DC2 type R '98. i thought there's supposed to be DC2 type Rx '99 with minor add ons from '98. but i've found in 1 of the threads here, somebody who owns a DC2 type R '00! waa... need more info!
I've never seen the DC2 Type Rx '99 in person nor the 2000 spec DC2. I have seen them on some websites, but even those are rare!!
I would love to see them in person too!
all typr RX r spec2000, manufactured end 99.
anybody?!?!?!? plz help....
for those who own type R dc2 whether 96 or 98...can plz check what chassis code.... plz plz plz...
thank you....
hmmmmm....
ok thanks brother achor..
whats the first 3 digits? what year model is urs btw...thanks mate...
tombstone said:
hmmmmm....
JDM DC2 SiR-G II year 96. stated as in the documents in japan. m'sian pink slip only state E-DC2. 1st 3 numbers ar? as in m'sian pink slip also,
no casis: DC2-1106039
no enjin: B18C-1103331
ok or not?
