y u wan to open itlah, but i dun think u will cos u will b adicted to it! :POriginally posted by edgar_raphael@Nov 28 2004, 15:46
tied so close, next time how to remove?
Originally posted by xtorm+Nov 28 2004, 19:49 -->
QUOTE (xtorm @ Nov 28 2004, 19:49 ) --QuoteBegin-edgar_raphael
@Nov 28 2004, 15:46
y u wan to open itlah, but i dun think u will cos u will b adicted to it! :P [/b][/quote] agree... no way i'm taking it off after spending hours doing it and wake up the other day with sore legs and back pain. |
sure... can lor...Originally posted by jdj6632@Dec 6 2004, 13:40
do these cable ties capable of enduring heat??
can use it to tie engine cables??
so far none of the cable ties have turn brittle.... and the force on the cable ties are distributed evenly, so not likely that it'll break..Originally posted by Esky@Dec 6 2004, 08:02
I really wonder how long these plastic cable ties can last under heat and stress... will probably break up one by one after a while, me thinks.
I've thot about DIY using those metal grounding straps instead... it's long so u don't need to tie many short cables many times, and u can probably use metal ring clamps to clamp it down. The problem would be securing the starting and trailing ends.
Goodridge steel braided hose is better compare to ProRS n more expensive than it.Originally posted by Autoracingsyndicate@Dec 5 2004, 01:15
Guys wanna ask sumthin compare ProRS n Goodridge steel braided which is better ?o is it the same?i guess goodridge is more expensive... :unsure:
