Just replace the RP18 resistor to 1.5k resistor its will work fine
i think at jln pasar it quite hard to find 1.5k resistor. how about 1.4k? or higher from that value?
any prob from that value?
its good if you lend me a handQuote:
That's is one way to do it....
Btw DC, want help on the Cel 14?
me?2 years ago my own car ecu had this trouble...
Never seen 1 with this problem from customer yet.
I suspect could be same cause as mine.... broken copper track .... trace from the iavc ecu pin into the pcb.... look for broken trace....
Worst case send it down to me... (i was the 1 that bought mfactory gear 3rd & 4th from u, sometime back)
---------- Post added at 06:56 AM ---------- 6 hour anti-bump limit - Previous post was at 06:53 AM ----------
Now fro the other way... the way i do it...
Remove- RP17 ( put alot of solder and just push it out)
Jumper- RP18. (000) or just small wire
Done!!!me?
i think for remove rp17 and jump rp18 just only work on p28.. seen a lot this method in us forum. hav u try it on p30?
Repaired 2 units of P27 this week....old age...
Ogip... try change this IC....
Looking at my stock, you should understand.... tq
Welcome... Keep me updated okay...
bring up post form diy....
just want to know what CEL code is this?happen after repair gear box and fix oil and atf cooler...
20 Electrical load detector
