FD single turbo setup
klgauto
Klang Sentral
Hi m selling these single turbo upgrade kits for Madza RX-7 FD3s .
all our products are in new condition & imported.
warranty provided please visit this web http://klgauto.tk for T&C.
you can reach me @ 012-7681200 mr see
kits #1
RX7 FD3S upgrade kit
TURBO SUPER T70
Compressor trim 60.4/83mm
A/R 0.84
Turbine trim 64/74mm
A/R 0.70
inlet 4"
outlet 2.5"
up to 650hp
S/steel top mount turbo manifold**
50mm wastegate
Blow of Valve BOV-007*
S/steel dump pipe**
Turbo flange kits**
Aluminum Intercooler & piping kits***
Silicon hose & s/steel T-clamp
Gasket & screw include
kits #2
http://i31.photobucket.com/albums/c386/klgauto/performance%20parts/100-0018_IMG_2.jpg
FD single turbo upgrade kits #2
MONSTER GT45
Compressor Trim 68.9/98mm
Compressor A/R 0.98
Turbine Trim 77.4/98mm
Turbine A/R 0.98
Inlet 4.25"
Outlet 3.5"
FOR 2.8L UP OR ROTARY 650~800HP
BRAND NEW IN BOX WITH COMPLETE GASKET
S/steel top mount turbo manifold with 50mm wastegate flange.
50mm wastegate
s/steel 50mm wastegate dump pipe
screw & gasket include.
Warranty against manufacturer defects
phat7 .. is made in Taiwan exported to USA spec.
bambino .. yup all balanced
the garret i bought alone cost more than this whole set.
the V-mount IC kits not arrive yet , will pm you once I got it .
btw our new shop located at : old klang road behind brother acc's shop (0127681200)
feel free drop by :D I got few turbine very suiltable for rotory
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
