hi,Originally posted by AlucarD@Dec 17 2004, 11:05
Wah ... 4bar = 58psi. Shold be ok gua... Forgot what is the max setting, should be around 60psi or was it 70psi.
Dun run to high pressure as it will be hard to start in the morning and injectors can go kaput. Nothing in your car will fly off cept maybe your money!!
hi,Originally posted by ezwong2002@Dec 17 2004, 13:58
:lol: like salesman, boss everyday give high pressure.. u think he will die or not? :lol: hmm.. why u wanna set your fuel pressure so high at idle 48psi? thats high dude... tune it down to 36psi should be ok liaw gua.. :)
hi my big brother kok keong.. heheheOriginally posted by KeonG@Dec 19 2004, 22:34
bro, what monster r u riding now ar?
Originally posted by tkk@Dec 19 2004, 23:13
hi,Originally posted by AlucarD@Dec 20 2004, 09:33
kk, of course your egt goes up when you reduce the fuel presssure since less fuel is going in. Look at it this way, your injectors are set to fire certain amount of fuel. By increasing the fuel pressure you're forcing more fuel in the fuel injectors, if pressure is too high and the injectors are constantly working at max cycle... it will kong lor.
870c at 7000 seems ok, most butt dyno reads between 800 to 900c. But since its hot here I personally would run a bit lower. 450cc injectors should be ok. Check fuel pump and get it tuned properly via a dyno.
Originally posted by tkk+Dec 20 2004, 09:44 -->
QUOTE (tkk @ Dec 20 2004, 09:44 ) --QuoteBegin-AlucarD
@Dec 20 2004, 09:33
hi, thanks for your advise again... i think i should go dyno tuning before i change to evo510cc injector... i'm worry when i change to bigger injector i need most stuff to handle it. m jus using the SAFC 5 button for reduce my air fuel now in low rpm. 6000-7000rpm my EGT is keep going up. is scarely when i install the EGT for monitoring. nowaday i seldom really rev up to 6500rpm above.. maybe because the EGT make me uncomfortable when the 850cc warning light come in... what is the normal fuel pressure should we set? this case i'm set to 48psi in idling. if i use 510cc injector i need to reduce make it balance right? [/b][/quote] kk, to reduce or increase the pressure on your FPR is entirely dependant of your set-up and tuning. So before you go and mod anything get the car tuned rite first. No point buying extra stuff when the current stuff works fine.. |
hi,Originally posted by AlucarD@Dec 20 2004, 10:43
. 012-2943515
