First the two screws u've mentioned..
Then carefully pry out the hazard light switch, and unplug the socket..
You will see a screw behind where the switch was.
pop out the clock and unplug the socket as well..
then with a few careful tugs here and there..u'll be able to remove the whole panel..
once the outer panel is removed,
unscrew the meter panel (2 screws on each side) and remove a couple of sockets from the back of the meter panel..
NOW, its up to u how to remove the clear plastic cover, cuz i THINK its not meant to be removed..and it'll crack easily!
good luck..
and when u put everything back together, the outer panel goes in easier if u push in the right side (near driver door) first.... =)
