For Bolt-on Turbo wannabe and all the sifoos here, i got question...
How to settle this knocking problem...what method can be use..bcoz our OEM ECU cannot recognize boost..can we just do...
1) -Fuel return Line & fuel regulator
2) -Fuel Pump
2) -Extra Injector & Injector Controller (AIC)
3) -AVC (actuator valve controller) so xpensive hehehe!!
4) -FMU (Fuel Management Unit) must do fuel return line first.. KSP got this FMU
5) -SAFC - so many said cnnot settle knocking..
6) - or "Check valves" to trick MAP sensor!,it bleeds off boost from the MAP sensor
so which one or method can be use??...that "check valves" who know which mech can do this...?
check this link for honda bolt-on project:
http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
2) -Fuel Pump
