- Joined
- Feb 10, 2007
- Messages
- 2,867
- Points
- 5,213
how about when high rev?what is the pressure?
in ur case, check your bearing clearance........hondatech ppl told that bearing clearance do affect the pressure... +-0.5 bar is very low that is harmful already... since ppl said,when pressure less then 1 bar the engine oil lights will going out already.....
mine is iddle 1 bar +-,crusing 2 bar plus,when start rev, the pressure going up a bit then drop...
any else can help?
regarding that buble..how about engine oil viscosity??does it deteriorate faster than usual??? perhaps too much piston ring gap?
or could be some pressure drop due to source of turbo oil feed??)![]()
finally issue has been solved, there was a bolt missing in the crankshaft that the owner changed which he bought elsewhere. didn't know that is the culprit
