MSD Ignition controller DIS-2 & DIS-4
ayil
For immediate sale.
MSD Digital Dis-2 Rm1450 SOLD!!
MSD Dis-4 Plus 4 (2 units) RM 1850 each ONE REMAINING!! NOW GOING FOR RM 1700!!
Slightly nego
All items used but in perfect condition. harness included.
Item in Bangi/Shah Alam
TECHNICAL FEATURES - DIGITAL DIS-2
Operating Voltage: 12-18 volts (neg. ground)
Operating Current: 5.3 Amperes @ 10,000 RPM
RPM Capability: 14,000 RPM - 4-Cyl. @ 14 volts
Ignition Inputs: 2 - DIS Type
Ignition Outputs: 2 - DIS Type
LED Indicator: Ign. trigger, low battery voltage
Tach Output: (+) 12 volt square wave, 40°
Duration
Rev Limiter: High RPM - Adjustable
Low RPM - Adjustable
Spark Duration: 20°- 4-Cyl. Max Sparks - 12
Energy Output Max: 105-115 milliJoules per spark.
Output Voltage: Primary (into coil): 460-480 volts
Secondary: (w/stock coil)
43,000 volts
Weight & Size: 3 lbs., 9.5"L x 4.5"W x 2.2"H
TECHNICAL FEATURES - DIGITAL DIS-4 PLUS
Operating Current: 10 Amperes @ 10,000 RPM
RPM Capability: 14,000 RPM - 4, 6, 8-Cyl. @ 14 volts
Ignition Inputs: 2, 3, 4 - DIS Type
Ignition Outputs: 2, 3, 4 - DIS Type
Duration
Spark Duration: 20°- 4, 6, 8-Cyl. Max Sparks - 12
43,000
volts
SMS/Call Ayil 0123923553
(If dial tone sounds different to standard (I'm overseas), please SMS
bro is this universal??any cars oso can install?
DIS - distributorless ignition system... example evos....
almost universal.
its designed for Distributerless Ignition Systems Ie cars that do not have a distributer. uses coil packs instead. the dis 2 can be used for 4 cyl wastespark systems and the Dis-4 can be used up to 8 cyl wastespark or 4 cyl sequential ignition.
most mitsu and 4cyl nissans can use this system. sorry to honda owners, you'll need a different system.
Which toyota engine??
Bump: 4 Cylinder cars with Coil On Plug setups can use the DIS-4
Toyota engine 4afe,7afe, 4age 20v,4age 16v
Bump: Which toyota engine??
I'm not very familiar with Toyota ignition systems. Basically if the system uses some sort of cam or crank angle sensor to trigger the ECU and uses coilpacks to fire the sparkplugs then the MSD is benificial to your car.
hi seller, can mitsubishi FTO V6 use MSD Dis-4 ?
do you provide installation? thanks
my 1jz runs on sequential. if i were to use your dis 4 does that means i have to rewire my wiring to make it run on wastespark?
