Chris since you have more experience on using different cams ,,,could you inform me which one has the highest peak RPM power,,,other than jun 4 ? For machine that has cut off 11,000rpm.
You probably have more experience than me in using high high lift cams. :confused_smile: I personally only have used GSR, ITR, CTR, Jun 2, Jun 3, Toda C, Buddy Club Spec 3+ and Omni 1. These are all relatively mild compared to the Jun4 u using.
I only can share what i have personally SEEN only but i never try before.
A B20B using Buddy club Spec 5, power peak only about 9200rpm. If a B16A i believe the peak power can be as high as 10,000rpm! And this B20B guy swapped his jun4 out for BC Spec5 even though power peak lower rev because the BClub5 made more power all over the curve except peak.
A B16A with Jun3 peak at 9200+. Same engine with TODAC peak about 8600rpm but made more useable power than Jun3 till about 8000+rpm.
A B16A using Toda Killer (don't know which spec cause there is 3 duration to use), he said his power band is about 6500rpm to 10000rpm. No dyno proof as they don't want to show us so i can't comment if it is true. hehe...
A B16A using NZ race cams again claim to peak at 10,000rpm but again not sharing any dyno sheet or sharing anymore info with me.
Many USA engine build i see B20's using Skunk2 Pro 2+ making power into the 9000rpm! Skunk2 claims that their Pro Series 3 can make power to about 9800rpm. These are currently one the more popular race cams in USA now.
I believe in making broader power band with more useable power throughout the rev rather than just Peak numbers at peak revs cause the wear and tear at those 10k rpm are just ridiculous. Unless you tell me you just use for Drag race only and are prepared to rebuilt after a year SIC drag battle then different story la. :regular_smile:
So, V8_nutter what cams you using in what block and the power you making?? Share la.. hehe..
