If you do not like too much of a booming sound from the sub, put it into a sealed enclosure or close the hole with an wooden MDF piece if you do not want to spend on a new box.
mnkh0027 said:If you do not like too much of a booming sound from the sub, put it into a sealed enclosure or close the hole with an wooden MDF piece if you do not want to spend on a new box.
spetnaz said:Does it means that a sealed box will produce 'softer' bass than a ported box?
buck-7 said:satria and hothatches will create more bass then sedan cars with the same woofer.
but have you tried facing the woofers in different directions, sometimes this works. like if its facing the back now, turn it around to face the front.
just a suggestion.
ir1 said:Yes, I have all the items in a box. For my pre-out, i only use 1 for amp ( i think cause the shop installed for me).
a 4g93 twin cam.
